Thread: Fatal Error Everytime I try to create a profile
    2009-03
    Default Fatal Error Everytime I try to create a profile
    I am having all sorts of problems with my AutoCAD Land Desktop. When I try to create a profile I get all these errors and when I try to save my computer crashes. Please help. I need this fixed ASAP. Thanks everyone.
    Delete existing profile layers [Yes/No] <Yes>: n *Invalid*
    18.286537
    Unknown command "LDD". Press F1 for help.
    18.286537
    0.000000
    Unknown command "495.00". Press F1 for help.
    *Invalid*
    Unknown command "SASKENERGY ACROSS 11TH ST". Press F1 for help.
    Unknown command "PEGCT". Press F1 for help.
    Unknown command "PVGRID". Press F1 for help.
    Unknown command "PFGCT". Press F1 for help.
    Unknown command "PEGC". Press F1 for help.
    Unknown command "PEGL". Press F1 for help.
    Unknown command "PEGR". Press F1 for help.
    Unknown command "PFGC". Press F1 for help.
    Unknown command "PGRID". Press F1 for help.
    Unknown command "PGRIDT". Press F1 for help.
    20.000000
    20.000000
    20.000000
    3.906492E+005
    5.774225E+006
    495.000000
    0.000000
    286.770982
    Unknown command "LEFT". Press F1 for help.
    Unknown command "PEGLT". Press F1 for help.
    Unknown command "PEGRT". Press F1 for help.
    Unknown command "PDGL". Press F1 for help.
    Unknown command "PDGR". Press F1 for help.
    2010-04
    Default Re: Fatal Error Everytime I try to create a profile
    Have you updated your LDD software with service Pack 2? I had the same problem a while ago, and that was the issue.
    2003-11
    Blue Springs, Mo.
    117
    I have this same issue (using 2008 LLD). I updated to SP2 still no help. Is there a setting that needs to be set? After updateing to SP2 now I can not plot. Do I have to reconfigure my plotter?
    2012-04
    That looks like the AutoCAD profile might not have the support path to LDD defined (possibly changed by the addition of another third party add-on)? I don't have good knowledge of all the support file locations for LDD but you can check by using the CONFIG command. By chance you might have multiple user profiles defined under the Profiles tab under Config, something like LDD that you could reload. If there is only one profile like Default, chances are something over wrote it and will need to rebuilt or reloaded.
  1. Fatal Error Generate Profile
    By hirampesante in forum AutoCAD Land Desktop - General
    Last Post: 2009-09-03, 04:41 PM
  2. Replies: 4
    Last Post: 2006-10-26, 02:36 AM
  3. Fatal Error with editing wall profile...
    By twiceroadsfool in forum Revit Architecture - General
    Last Post: 2006-02-05, 07:01 PM
  4. Replies: 2
    Last Post: 2005-11-04, 01:46 AM
  5. fatal error while exploding profile from 3D solid
    By IanR in forum AutoCAD 3D (2006 or below)
    Last Post: 2004-09-27, 10:00 PM
