Thread: Replace block with an updated one
    2015-12
    7
    Question Replace block with an updated one
    In a drawing I insert blocks from a block library I´ve created, but some of the blocks in the library have beed edited, I now want to update all blocks in the drawings with the changes, but if I insert the edited block, I get an instance of the old one inside the drawing, how can I update the blocks?
    got AutoCAD LT for Mac 2016
    0,0,0 The Origin
    8,570
    Default Re: Replace block with an updated one
    You need to use the Insert command and the "browse" button and navigate to the modified version of the block.
    2016-12
    9
    Did you ever get your answer?
    2005-06
    in the upper right corner
    3,381
    Quote Originally Posted by durrcraig740145 View Post
    This is an old thread... and we don't know if the OP got their answer or even came back to read it.
    However... It sounds like they have a library of updated blocks and they want to change blocks in existing drawings to the updated ones.
    If that is the case, as jaberwok mentioned in his reply, you would "browse" to the updated block and insert it from there, and AutoCAD will ask you if you want to "Redefine block" and you would say yes.
  1. Block Replace
    By darjuliav674719 in forum AutoCAD General
    Last Post: 2014-06-12, 07:53 PM
  2. Replies: 0
    Last Post: 2012-09-20, 04:53 PM
  3. 2012: Replace a Block with a Dynamic Block
    By Mac Demer in forum Dynamic Blocks - Technical
    Last Post: 2012-05-21, 09:49 PM
  4. block replace
    By modulor in forum AutoCAD General
    Last Post: 2009-11-30, 10:39 PM
  5. Replace one block with another
    By gfreddog in forum AutoLISP
    Last Post: 2008-02-08, 02:18 PM
