Thread: Rotate Project North - Fix needed
    Wish List Administration
    2011-08
    4,581
    Default Rotate Project North - Fix needed
    Summary: Rotate Project North command under Project Location]Position does not rotate everything. We want it to rotate everything like the command says it should do.
    Description: Several key items are still not rotating properly and have to be rotated manually since Version R14 -
    The following is a list of object types not rotated by the Rotate Project North command:
    • Text
    • Some Floor-Based Component Families
    • Decals, Symbols, Property Lines
    • Detail Lines, Detail Component. Detail Groups
    • Masking Region
    • Repeating Detail
    • Filled Region
    • Revision Cloud
    Autodesk's current suggestion is...
    To resolve this issue, you need to manually rotate any excluded object types after using the Rotate Project North command ...Really
    Having this fixed would be an amazing time saver.
    Product and Feature: Revit Architecture - Site tools
    Submitted By: k.bel4design on 04/12/2016
    AUGI Addict DaveP's Avatar
    2002-12
    St Paul, MN
    1,569
    Default Re: Rotate Project North - Fix needed
    Check out the new features of 2017.
    http://help.autodesk.com/view/RVT/20...C-E66FF1F2C228
    Go back to AutoCAD? I'd rather lose my right arm!
