Copy a Drawing Sheet within the Same Inventor Drawing File
Summary: The ability to duplicate a drawing sheet within the same Inventor drawing file.
Description: Inventor has no direct way to duplicate a drawing sheet in the same IDW or DWG file. To duplicate a sheet you need to use another IDW file for temporary storage. The other IDW has to be either be a copy of the original IDW,or an empty IDW. Then you have to copy and paste the sheet you want to duplicate between these IDW's. This is utter nonsense, and wastes a fair amount of time, and creates excess files that you need to keep track of and delete. The ability to copy a sheet within the same drawing needs to be a top priority, and I hope everyone who reads this wish votes for it. Thank you.
Product and Feature: Inventor - API
Submitted By: eclark.137991 on 04/13/2016
Re: Copy a Drawing Sheet within the Same Inventor Drawing File
Description: Inventor has no direct way to duplicate a drawing sheet in the same IDW or DWG file. To duplicate a sheet you need to use another IDW file for temporary storage. The other IDW has to be either a copy of the original IDW, or an empty IDW. You then have to copy and paste the sheet you want to duplicate between these IDW's. Every user must be told, discover on there on, or researched this "trick" or " tip", since the software has no direct way to copy a sheet. This is utter nonsense, wastes a fair amount of time, and creates excess files that you need to manage. A user should be able to RMB on the sheet, select copy, then RMB and select paste, and be done with it. The ability to copy a sheet within the same drawing needs to be a top priority, and I hope everyone who reads this wish votes for it. Thank you.
Description: Inventor has no direct way to duplicate a drawing sheet in the same IDW or DWG file. To duplicate a sheet you need to use another IDW file for temporary storage. The other IDW has to be either a copy of the original IDW, or an empty IDW. You then have to copy and paste the sheet you want to duplicate between these IDW's. Every user must be either told, discover this method on their own, or researched this "trick" or " tip", since the software has no direct way to copy a sheet. This is utter nonsense, wastes a fair amount of time, and creates excess files that you need to manage. A user should be able to RMB on the sheet, select copy, then RMB and select paste, and be done with it. The ability to copy a sheet within the same drawing needs to be a top priority, and I hope everyone who reads this wish votes for it. Thank you.
Product and Feature: Inventor - Drawing Manager
This should have been added already!
- You may not post replies
- You may not edit your posts
Forum Rules
