Thread: Reading AECC entities in civil 3d 2015
    2015-04
    Default Reading AECC entities in civil 3d 2015
    I am about to begin a project using AutoCAD Civil 3d 2015.
    I am receiving civil 3d drawings from a consultant that is using Civil 3d 2016.
    In the profiles that the consultant created all of the callouts for utility crossings do not come across.
    All I get is a box with an AECC message.
    I have been told that I either need the correct object enabler or a 2016 upgrade.
    Is there another way?
    Thanks
    2009-11
    5,719
    Default Re: Reading AECC entities in civil 3d 2015
    Welcome to AUGI.
    This is something that should be established in the initial contract, as to which version of Civil 3D shall be used. This would allow for everyone involved to work on the same version, and mitigate situations like this.
    That said, you're here now - the simplest way for you to obtain their data is for you to upgrade. Next would be either of the bitter pills of asking them to provide you LandXML, which inherently loses all layer, style, and label assignments, or for them to EXPORTTOAUTOCAD, which inherently loses all dynamic functionality.
    If you're on subscription, urge your CAD/IT admin to download and install 2016 ASAP, as you can bring your setup forward during initial install / first run (mostly, some fine tuning thereafter, as always), but you'd be up and running, and able to use the files you've been provided with the least effort required for everyone.
    Cheers
    Computer Specs:
  1. 2015: ACA 2015 Wall Tags not reading Prop Set
    By schilds937 in forum ACA General
    Last Post: 2014-10-10, 03:09 PM
  2. 2015: Installation of Civil 3D 2015
    By Robert Platt in forum AutoCAD Civil 3D - General
    Last Post: 2014-04-22, 05:44 AM
  3. Civil 3D 2012 reading Civil 3D 2011
    By egmoreno in forum AutoCAD Civil 3D - General
    Last Post: 2012-01-24, 05:40 AM
  4. Aecc points from civil...How do I make them query-able in autodesk map?
    By rawuser.72284 in forum AutoCAD Map 3D - General
    Last Post: 2006-03-13, 02:35 PM
