Results 1 to 6 of 6
Thread: Modifing label of one point in all section views
    2016-03
    28
    Default Modifing label of one point in all section views
    Hi folks.
    Need little help.
    Please see picture attached.
    I have an small assembly that needs to label two points on it.
    Civil 3D does this with no problem.
    BUT, the problem is that since these two points are VERY CLOSE together, I need to MANUALY move labels apart in every section view (and I have around 50 of them)
    Is there any way to skip this?
    2014-08
    447
    Default Re: Modifing label of one point in all section views
    I'm not sure here have not tried this, but on the PVI labels for FG there is a stagger option for labels that overlap
    2016-03
    28
    remi I dont understand you.
    Can you please explain a bit more where to find this function and how to use it.
    2009-11
    5,714
    From the Civil 3D 2016 Help:
    To Stagger Profile and Section Labels
    Cheers
    Computer Specs:
    2016-03
    28
    @BlackBox
    I cant seem to get this working.
    I applied labels to my corridor points using following method:
    RightClick on the cooridor in one of the section views
    then
    EDIT CODE SET STYLE
    and there for each corridor POINT, I can assign a label style that will be displayed in ALL section views.
    But theres no staggering options...
    Cant find it.
    2016-03
    28
  1. Replies: 2
    Last Post: 2015-11-13, 07:52 PM
  2. Point Cloud 2D Section and Elevation Views
    Last Post: 2014-10-24, 10:10 PM
  3. 2013: Point Label Style - Dragged State - Point to Node
    By sebastien795355 in forum AutoCAD Civil 3D - General
    Last Post: 2013-11-04, 04:10 PM
  4. Survey Point and Project Base Point Visible in new views
    By amjones in forum Revit Architecture - General
    Last Post: 2013-03-12, 10:23 PM
  5. Placing insertion point at mid-point of flange on a steel section
    By Spenner in forum Dynamic Blocks - Technical
    Last Post: 2007-06-18, 01:53 PM
