Thread: Trying to add datum to corridor and it shows up weird in sections
    2013-03
    Can you say DERECHO, Iowa
    66
    Default Trying to add datum to corridor and it shows up weird in sections
    First image is of my cross section with the topo surface, and proposed assembly (pipe networks are also in the section sources, but no pipes in this section.) The second section is only different in that the proposed corridor surface is shown (created within the corridor properties under the surfaces tab - the surface has the datum code added to the surface as seen in the second image.) My question is what I'm doing wrong to get the datum to show up like that? I'm trying to compute materials and my dirt quantity gets thrown way off by this. Does anyone else see this happen? I'm a noob to intermediate Civil 3d user, but this seems to happen to all the guys in my office..
    2013-10
    Default Re: Trying to add datum to corridor and it shows up weird in sections
    The second image may be missing surface boundary. I think you should check the corridor surface boundary whether assign or not.
  1. can't see corridor in cut sections in 3d mode
    By afro100918898 in forum AutoCAD Civil 3D - Corridors
    Last Post: 2011-11-18, 05:33 AM
  2. View/Edit Corridor Sections
    By dbreedlove in forum AutoCAD Civil 3D - General
    Last Post: 2010-08-11, 08:56 PM
  3. View/Edit Corridor Sections
    By Ryan-13 in forum AutoCAD Civil 3D - Corridors
    Last Post: 2010-04-30, 05:00 AM
  4. Weird changes to wall layers in sections RAC 2010 and 2011
    By Gadget Man in forum Revit Architecture - General
    Last Post: 2010-04-28, 12:11 AM
  5. Corridor surface (Datum wrong)
    By fusi in forum AutoCAD Civil 3D - Corridors
    Last Post: 2009-05-04, 02:48 PM
Tags for this Thread
