Thread: Convert Proposed Surface Boundary to Feature Line In Order to Grade to Existing Surface?
    2012-11
    8
    Default Convert Proposed Surface Boundary to Feature Line In Order to Grade to Existing Surface?
    I have a proposed surface shown here:
    To make that surface, I used plines with assigned elevations and feature lines, all assigned to PROPOSED surface as breaklines (i.e. I have not used any grading groups). Now, I'm trying to tie this edge of PROPOSED into the existing surface at a certain grade, but need that line green edge to be a feature line somehow in order to do the grading group tie-in. How do I create a feature line from the PROPOSED surface extents that has x, y, AND z data, so that I can grade from that feature line to the existing surface?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,106
    Default Re: Convert Proposed Surface Boundary to Feature Line In Order to Grade to Existing Surface?
    Extract the boundary from the surface. Then convert the extracted object to a feature line. Then grade to the desired surface.
    2012-11
    8
    This was the answer. Thanks so much.
  1. Balance Grade to an existing surface
    By dchope in forum AutoCAD Civil 3D - Grading
    Last Post: 2014-08-29, 08:41 PM
  2. 2012: Creating Grade Line (surface profile) Over actual Pipe Location
    By karen.cohen593070 in forum AutoCAD Civil 3D - Pipes
    Last Post: 2013-10-04, 08:24 PM
  3. Offset feature line to surface
    Last Post: 2012-06-12, 05:47 PM
  4. Feature Lines Grade to Surface
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2010-11-16, 02:10 PM
  5. feature line/surface style
    By oneill.tracy in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2009-04-09, 07:52 PM
Tags for this Thread
