Thread: Same family different 3D design
    2016-04
    Paris Area
    29
    Question Same family different 3D design
    Hi everyone,
    I am new to Revit and its families. I am currently building a library of objects and I have a question:
    How do you build a family that has types with different 3D representations?
    Example:Family A
    Type 1: a cube
    Type 2: a sphere
    I am working on Revit 2016 and if you need more information on how i am proceding feel free to ask for more details.
    Thank you very much!
    2001-12
    Irvine, CA
    7,567
    Default Re: Same family different 3D design
    Each solid form has a parameter called Visible. When you examine that parameter you'll see a small gray button to the right, that's the Associate Family Parameter button. It will open a dialog that will allow you to create a parameter to control the Visible parameter with a check box. Create one called Show Sphere and then for the other create one called Show Cube. In the Family Types dialog create a formula for one of the other like this:
    Show Sphere - Formula should read: Not(Show Cube)
    Just reverse that logic if you'd prefer to uncheck or check Show Sphere, as a user turn one on or the other. Watch a Video?
    2016-04
    Paris Area
    29
    Thank you! Works fine
  1. Replies: 0
    Last Post: 2015-08-07, 05:38 PM
  2. Replies: 0
    Last Post: 2014-11-30, 07:15 PM
  3. Replies: 0
    Last Post: 2014-11-13, 11:07 PM
  4. Replies: 0
    Last Post: 2013-04-08, 07:53 PM
  5. Family Design Bar - Control button
    By Chris.N in forum Revit Architecture - Families
    Last Post: 2008-05-14, 01:29 PM
