Results 1 to 10 of 11
Thread: Dwg to Jpeg?
    Member nick.79912's Avatar
    2004-12
    Pittsburgh, PA
    10
    Default Dwg to Jpeg?
    I work for a small architectural firm in Pittsburgh, PA and the lead architect and I have been trying to come up with a fast way to get a .jpg or any type of image file from a paperspace .dwg. Now either we are just overlooking something or this isnt an option within AutoCad's pulldown menu's. If anyone could help out I would appreciate it greatly.
    Thanks
    2004-07
    Detroit Michigan
    2,508
    Default Re: Dwg to Jpeg?
    What about using alt/print screen and then pasting the screen image into
    microsoft paint????
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    MS Paint won't save to jpeg format unfortunately. Check out this thread for some more options: Click Here
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2004-12
    Pittsburgh, PA
    10
    yah I've done the print screen deal and saved into MS Paint. I was just thinking there could be a faster way.
    I could stop if I wanted to Tom Dorner's Avatar
    2003-11
    Phoenix, AZ
    371
    If you have Adobe Acrobat Professional, you can print the ACAD layouts as PDF's then open them up with Acrobat and "save as" to a JPEG.
    HTH
    Tom
    AUGI Addict blads's Avatar
    2015-10
    out cycling somewhere... I wish...
    2,285
    or another way you probably wont want to hear...
    if you use Revit any image on the screen can easily saved as a jpg
    Cheers @blads
    Mac Geek | Building Design Suite 2020 | Semi-Retired Building Designer / CAD-BIM Trainer | Autodesk Certified Professional
    2015-12
    4,730
    Forget what I said earlier. Try using the JPGOUT, PNGOUT, BMPOUT or TIFOUT commands when on a layout tab.
    AutoCAD CAN TOO!!!
    2004-07
    Detroit Michigan
    2,508
    Quote Originally Posted by bladams
    Yep, and Ive received way too many "Screen Dumps" from my sales department, thinking that I can do some Cad work. Its funny when they do not believe that it is not sufficient enough..........looks like chicken, but doesn't taste like chicken, lol.
    2004-12
    34
    Red face Re: Dwg to Jpeg?
    I have used the JPGOUT command, just one thing that you will learn is the background of AutoCAD when you create the Jpeg will be the background color of your Jpeg. In other words, if you work in AutoCAD with a black background, the Jpeg will have a black background. You will have to go into the Options to change your colors. White background will not print.
    2004-12
    Pittsburgh, PA
    10
    Quote Originally Posted by Steve_Bennett
    AutoCAD CAN TOO!!!
    Hey man thanks alot for the help. those commands do just what i want. only bad thing is they are in poor resolution(1000x520) but oh well cant expect everything from autocad.
  1. 2011: Frame around jpeg
    By dcooper.cse in forum AutoCAD General
    Last Post: 2010-05-17, 12:05 PM
  2. import jpeg
    By johnf.77896 in forum Revit Architecture - General
    Last Post: 2010-02-10, 08:48 PM
  3. JPEG
    By trosaIII in forum AutoCAD LT - General
    Last Post: 2009-02-05, 02:40 PM
  4. Transfert de DWG à JPEG
    By sdelisle_hm in forum AutoCAD General
    Last Post: 2008-01-23, 03:47 PM
  5. DWG to BMP or JPEG
    By jamesvue1981 in forum AutoCAD Plotting
    Last Post: 2004-12-30, 12:41 PM
