Results 1 to 9 of 9
Thread: Total number of sheets in a single drawing with multiple Layouts
    2016-05
    Post Total number of sheets in a single drawing with multiple Layouts
    My name is Brandon Wilson, and I know that this is an old discussion, but since it has been a while since I have used AutoCAD ( I am using AutoCAD Electrical 2017), why doesn't Autodesk have a Total Layout count yet?
    Why do we still have to spend so much time for something that should be very simple.
    I am currently using the Sheet Set's CurrentSheetNumber to get the number of the current sheet which I use in my Title Block Attribute (Sheet # of #); it is the count of the sheet, which is the first # attribute, but there is no Property for the Total Number of Layouts; can someone please help me.
    Thank You!
    9,805
    Default Re: Total number of sheets in a single drawing with multiple Layouts
    Quote Originally Posted by bwilson727567 View Post
    ....why doesn't Autodesk have a Total Layout count yet?
    I don't know.
    .....but there is no Property for the Total Number of Layouts; can someone please help me.
    Create a custom 'Sheet Set' property and populate it yourself.
    We (with help...) created our own routine to renumber the sheets 1-X and populate our custom property with the count "X" so we didn't have to manually do it.
    AUGI Addict jpaulsen's Avatar
    2002-04
    Colorado
    2,020
    That's what we've been doing for, WOW, 10 years now since 2005 was released. You just have to remember to update the number if you add or remove sheets. Keeping the number updated hasn't been a problem in my office.
    9,805
    Quote Originally Posted by jpaulsen View Post
    Actually, 12 years, right?
    We're on 2017 now.
    2002-04
    Colorado
    2,020
    Man how time flies.
    Tallahassee, FL USA
    3,667
    Long long ago in school I was taught the key or index sheet didn't count and the page after was sheet 1 same as page 1 in a book. Most offices including ours count the key or index sheet as sheet 1. Maybe AutoCAD's afraid to open that can of worms. They could make it an option like counting the first row as a header in Excel.
    5,719
    Another option, depending on how you number your sheets - if you use numbers only, and NOT numbers + letter(s) - you could simply assign the total value in 'XX of YY Sheets' the Sheet Number of the last Sheet in your Sheet Set.
    So long as you always move that Sheet within the Sheet Set, and do not remove it from the Sheet Set, simply renumbering will keep your 'total' number accurate.
    If you have multiple Sheets within a single drawing, or Subset of Sheets, simply do the same for the last Sheet in that particular Subset of Sheets.
    If none of that works, because you DO use numbers + letter(s) in your Sheet numbering convention, then either use the custom Sheet Set Property as mentioned above, or a LISP that populates the value automagically using the following to populate your title block's attribute value:
    (itoa (length (layoutlist)))
    Cheers
    9,805
    Cool Re: Total number of sheets in a single drawing with multiple Layouts
    ......I was taught the key or index sheet didn't count and the page after was sheet 1 same as page 1 in a book. Most offices including ours count the key or index sheet as sheet 1. Maybe AutoCAD's afraid to open that can of worms. They could make it an option like counting the first row as a header in Excel.
    Agreed. In our custom solution, I built in an option because we had TWO sheet 1's. (Two different cover sheets...it's a long story).
    So anyway, ours optionally numbered like this:
    4
    5,719
    4
    The 'international' firm I came from used to "Issue" plans, for a given submittal, so I had an ISSUE_DATE, and ISSUE_DESC custom Sheet Set Property mapped into our title blocks.
    Utility Submittal? Change the custom Sheet Set Properties without having to open a single drawing (10 seconds?), and Publish the plans you need.
    Now with the 'small' firm, I have to have multiple Cover sheets (one for each submittal type).
    On the up tic... They do pay better though, the 'small' firm. Haha
  1. Single Detail on multiple sheets
    By katysue in forum Revit - Platform
    Last Post: 2008-09-15, 10:33 PM
  2. Spread a single view across multiple sheets.
    By eric.anastas in forum Revit Architecture - General
    Last Post: 2006-11-10, 09:36 PM
  3. Total number of sheets
    By jamie.casile80054 in forum AutoCAD Fields
    Last Post: 2005-07-14, 12:39 PM
  4. Routine to count the number of Layouts in a drawing
    By pgastelum77763 in forum AutoLISP
    Last Post: 2005-07-07, 02:15 PM
