Thread: Use a multileader as a callout block in SSM
    I could stop if I wanted to jpcadconsulting347236's Avatar
    2011-09
    300
    Default Use a multileader as a callout block in SSM
    Hi gang,
    Been a while. How's everybody?
    I'm setting up a template sheet set at a new client. This client uses mleaders with a block as their detail callout tag.
    I have all the other blocks (elevation tag, detail title, section tag, etc.) set up and working as expected in SSM. However, I can't get the mleader styles to work.
    1. They are not blocks so I can't select them in the "callout blocks" section of the SSM properties dialog box.
    2. If I make blocks out of an mleader entity, I can add them in the "Callout blocks" section and they insert, but they need to be exploded to be used... and, their fields (View Number/Sheet Number) are not populated.
    Is there a way to do what I want? Can you use mleaders as callouts in SSM? Can a person be truly happy?
    Thanks as always for any help...
    James Pertusi
    CAD Applications Consultant
    1 (646) 773 4834
    www.jpcadconsulting.com
    2009-11
    5,536
    Default Re: Use a multileader as a callout block in SSM
    Not sure that I understand; can you not insert a FIELD in the MLeader, and reference the desired SSM Sheet, Sheet Set, Custom Properties?
    Cheers
    Computer Specs:
    Dell Precision 3620, Core i7-7700K 4.2GHz, 64GB RAM, Samsung 970 Pro M.2, 8GB NVIDIA Quadro P4000
    2011-09
    300
    I can do that manually.
    But there is no way to add an mleader to the Sheet Set properties so I can right click on a Sheet View, Select "insert callout" and insert the callout with the fields populated automatically.
    Easy with a block... in fact my section and elevation tags work perfectly.
    If I make a block out of an mleader object (so that I can add it in the sheet set properties) I need to explode it after I insert it and then the fields are not populated.
    Does that help? I feel like I'm confusing matters.
    James Pertusi
    1 (646) 773 4834
    2009-11
    5,536
    I'd have to tinker, as I do not currently use this aspect of SSM. However, after some reading on this via KB, it appears as though Autodesk stopped developing SSM (in 2006-ish?), before MLeaders were introduced... And subsequently never found time to update SSM.
    That said, since adding them as a Block works, but requires they subsequently be EXPLODEd, you could implement a Reactor that filtered for Blocks of specific names that are appended to the DB, store their ObjectId(s), and programmatically Explode ghose ObjectIds following CommandEnded event.
    The best alternative I can offer, would be to setup some MLeaders with FIELDs, and add to a custom Palette.
    Cheers
    Computer Specs:
  1. Replies: 0
    Last Post: 2016-02-03, 07:48 PM
  2. Multileader User Block Colors
    By aswearingin in forum AutoCAD Customization
    Last Post: 2013-10-04, 03:40 PM
  3. 2008: Multileader with User Block
    By dglennon in forum AutoCAD General
    Last Post: 2011-10-06, 12:28 AM
  4. Multileader w/ user block
    By h.jobe in forum AutoCAD Annotation
    Last Post: 2009-06-08, 07:52 PM
  5. Replies: 7
    Last Post: 2007-05-31, 01:14 PM
Tags for this Thread
