Thread: Civil 3d Surface - Building with split levels - How to accurately show in surface for fill
    2016-03
    USA
    8
    Default Civil 3d Surface - Building with split levels - How to accurately show in surface for fill
    I am trying to accurately show amount of fill for my surface. I have a building that is split level - I need the section to show a definite vertical line between the two different elevations. Right now all I can get is a sloped line between the two. I know what I want but I can't seem to get there. I know some of you more experienced folks out there can help me!
    Cairo - no, not Illinois
    4,762
    Default Re: Civil 3d Surface - Building with split levels - How to accurately show in surface for fill
    true vertical in a TINN is not possible. The upper feature line needs to be offset from the lower- although than can be a tiny amount. like 0.01 ft
    2016-03
    USA
    8
    Thank you, cadtag!
  1. 2013: Editing Civil 3D Surface using Edit Surface command
    By louise.hilton861522 in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2012-11-15, 09:55 AM
  2. 2012: Surface Cut/Fill Balance with defined few tie in levels
    By Maritana in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2012-03-28, 01:56 PM
  3. split surface for cut/fill volume site
    By o_dragos in forum Revit Architecture - General
    Last Post: 2010-04-12, 09:02 AM
  4. show surface patterns below other surface
    By DoTheBIM in forum Revit Architecture - General
    Last Post: 2009-06-04, 01:20 PM
  5. Subregion vs. Split Surface?
    Last Post: 2006-03-06, 04:27 PM
Tags for this Thread
