Results 1 to 1 of 1
Thread: Custom Subassembly does not show up in section view
    2013-07
    Default Custom Subassembly does not show up in section view
    I have created a Subassembly with SAC 2015(please find the attached file), for an infrastructure network wet utilities, potable water, storm water, irrigation and foul sewer.
    In Civil 3D i created alignments profiles and then the corridors for the wet utilities.
    The problem is when i try to create a section view, the corridors for other utilities does not show up.
    But there is something wierd and it happens when i create an alignment after the utility corridors are already created.
    If i create the alignment which i will use for sample lines (roadway) and then create wet utility corridors, everything goes fine and i see all data on the section view.
    Any help would be appreciated since i tried so hard and could not figure out the problem.
  1. Custom Subassembly!!
    By a.navarrete in forum AutoCAD Civil 3D - General
    Last Post: 2014-05-01, 01:34 AM
  2. 2012: show only fg centerline elevation in section view
    By chiju20 in forum AutoCAD Civil 3D - Sections
    Last Post: 2014-04-23, 07:35 PM
  3. 2013: Walls don't show in section view
    By stevomatic in forum Revit Architecture - General
    Last Post: 2012-11-03, 02:15 AM
  4. 2013: How do I modify the side to which the levels text show on section view?
    By mikz12345100664 in forum Revit Architecture - General
    Last Post: 2012-10-23, 01:37 PM
  5. Custom Subassembly?
    By coronadog in forum AutoCAD Civil 3D - Corridors
    Last Post: 2007-08-02, 01:24 PM
