Results 1 to 10 of 10
Thread: 'Recent' Pop-Up Disappears When I Move The Cursor To Select A 'Recent' Project
    2001-11
    236
    Default 'Recent' Pop-Up Disappears When I Move The Cursor To Select A 'Recent' Project
    In sheet set manger, in 'Recent' when I pick the pull down to open a recent project, I can see the recnet projects,
    in the pop-up window. However, when I move to cursor to pick a recent project, the pop-up window disappears.
    Yes, I can create a new sheet or subset, open a new sheet from the Open button and even publish from the
    sub or 'sub-sub' menu.
    By the way, it does not matter if the pop-up is on the left or the right of the Sheet Set Manager.
    Cairo - no, not Illinois
    5,069
    Default Re: 'Recent' Pop-Up Disappears When I Move The Cursor To Select A 'Recent' Project
    same thing happens here, however if I pull the cursor to the side of the list of recent dst files, (without, mind you going all the way off, just off the main dialog bounds)
    then it works.
    funkyess abounds.
    9,804
    You have to keep the cursor in the "green" zone (shown here).
    If it goes into the "purple" zone, which is a natural movement, then the "recent" list goes away.
    Poor UI/UX
    5,069
    a picture is worth a thousand words -- thanks for posting that
    5,719
    Poor UI/UX
    [Autodesk]: That behavior is 'As Designed'.
    9,804
    I suppose they are piggybacking on some Microsoft drop-down control, and I can see *why* it happens, but they need to sit down and USE the tools they make.
    I would be okay with the list of recent files going away if the cursor leaves the area where is says ["Recent", "New Sheet Set", and "Open..."], but the fact that this is even a topic here shows that the current process #Fails.
    5,719
    That's the issue at it's core - what little they do use of the tools they make, is done in reference to what real-world production experience they might have (some of them have zero CAD experience, just a Master's degree) - which as I just learned about one of the 'better' UX members, they last worked with CAD +/- 20 years ago.
    This (to my mind) explains why they're so comfortable with the current lack of performance, lack of efficiency & effectiveness.
    That is correct; each Menu Item inherits certain Properties, Methods, and Events from the .NET Framework used to develop it.
    What could be done to help accomplish this, is for Autodesk to tailor the 'hover' Event handlers for the 'top three', such that focus is not given to one of those three Menu Items while the cursor is in motion... Only when it stops on one of them respectively.
    A loosely related example of this, is how Owen sub-classes the dialogs used within AutoCAD in order to expose the ability to resize them... Similarly, this could be done here (I believe), but such capability is not currently exposed to .NET API (Owen used ObjectARX [C++]).
    Anyway... Wishful thinking, on our part.
    Cheers
    5,069
    Of course -- if I design a septic system to discharge over a well field, that's perfectly fine. After all, it's 'As Designed'
  1. Recent views list, favorites list, and tabbed project browser
    Last Post: 2014-01-13, 12:48 PM
  2. Replies: 3
    Last Post: 2013-03-27, 05:41 PM
  3. 2011: Fix for Sticky Cursor in recent Autocad Releases
    By mleisk in forum AutoCAD General
    Last Post: 2013-03-05, 06:18 PM
  4. Project File sizes not bloating in recent build
    By Henry D in forum Revit Architecture - General
    Last Post: 2007-12-05, 09:16 PM
  5. Recent Project in Victoria
    By Joef in forum Revit - Gallery
    Last Post: 2005-12-09, 09:48 AM
