Thread: Vault 2016 - File check-in file names too long
    2016-07
    4
    Exclamation Vault 2016 - File check-in file names too long
    Good day.
    I have a problem where, when I check in files to Vault from Outlook or elsewhere, the file name ends up being too long.
    • The check in process gives me no warning to say that the file name is too long.
    • It doesn’t even give me the option to give the file a smaller name during check-in.
    Instead, I only find out when I try to open the file later.
    • But when I get to that point, I can’t even rename the file, to correct the problem – it gives me the same error.
    • I end up, unable to do anything to the file, except try delete it - and it still gives an error message then.
    Please tell me the best way to prevent this from happening, or at least a workaround.
    If there is a setting that prevents outlook from prefixing attachments with their parent email’s subject, I would be grateful to know about this and where to find it - AutoDesk help files are not incredibly helpful.
    2016-09
    Default Re: Vault 2016 - File check-in file names too long
    Long Path Tool is the perfect utility that can solve all the long path issues. Download this software online.
    2016-10
    You can use LONG PATH TOOL to solve this issue. It will definitely work for you.
    2017-02
    Hello,
    I had the same problem. I didn´t know what to do so I searched on the internet for some solutions.
    And I read about Long Path Tool, which is a great tool in these type of cases.
    It worked really well. Hope it works for you too
    2017-04
    Long Path Tool is useful here
    2020-10
    United States
    Long path tool is also really worked for me too. iT is very simple to learn.
  1. 2016: Inventor Check In Trouble with Vault Basic 2016
    By jnewton534097 in forum Inventor - General
    Last Post: 2016-04-25, 04:53 PM
  2. 2014: Autocad 2014: file names on the file tabs are missing!
    By mephasm in forum AutoCAD General
    Last Post: 2013-04-29, 07:20 AM
  3. Replies: 19
    Last Post: 2007-10-17, 03:11 PM
  4. Spaces in, dashes in or long file names cause print failure.
    By weazel14 in forum AutoCAD Plotting
    Last Post: 2006-07-07, 05:53 PM
  5. Beware of long file names when exporting...
    By Henry D in forum Revit Architecture - Tips & Tricks
    Last Post: 2004-02-08, 09:02 PM
