a.ghensi689507
Hi all,
I was wondering what it takes to build some dynamo nodes able to interact with autocad and Civil 3D. I saw what can be done with the bridge package, and I would like to automate it further by accessing the civil 3D document instead of having to export the report.
After some research I figured out that I cannot control autocad with .net api from an outside process, so the options are:
1 - write the nodes with the Interop library/ COM API
2 - use some IPC techniques (WCF? WEB api? simple Named Pipes?) and write a .NET AutoCAD/Civil Plugin that act as a server for the Nodes calls.
#1 can be really slow, and since everyone is saying I should avoid COM, then so be it. But #2 seems like a lot of work to me, especially because I never did any IPC.
Is there a magic wand to expose all the AutocAD .NET API via some IPC mechanism?
Did you come up with better solutions?
