Thread: Import Dimention style from another drawing?
    2015-12
    7
    Default Import Dimention style from another drawing?
    I want to use a dimention style in multiple drawings, can I copy/export a dimstyle and re-use it in another drawing?
    2005-06
    in the upper right corner
    3,524
    Default Re: Import Dimention style from another drawing?
    Quote Originally Posted by eivber View Post
    Absolutely, the best way to do this is use Design Center and drag the dimstyle(s) or just about anything else from one drawing to the one you're in.
    Many users have a template drawing file that contains lots of things they use over and over and either start a new drawing with that template, or use the template to drag stuff from.
    Have a look into Design Center (ctrl+2) or "adc" on the command line.
    Also look into template files.
    HTH
    (BTW I don't know how all that works with Mac, but that's how it's done in the normal world
    2015-12
    7
    I dont think the Mac version has a Design Center, Ctrl-2 brings up the Content window.
    However, I found out that if I copied a leader from one drawing to another, the DimStyle came along so I could choose it from the Dimension Style window.
    2005-06
    3,524
    Yes that will do it too, it brings the text style associated with the dim style as well.
  1. 2016: Temporary dimention don't appear when clicking to air terminal
    By danezeq390391 in forum Revit MEP - General
    Last Post: 2016-08-02, 10:22 AM
  2. 2014: How do you import a sheet set manager style into a new drawing?
    By rmclemore in forum AutoCAD Sheet Set Manager
    Last Post: 2014-10-27, 06:57 PM
  3. 2011: Dimension Style Import
    By Twolly in forum AutoCAD General
    Last Post: 2013-01-21, 06:56 AM
  4. Import Style and standard
    By dr_fleau in forum VBA/COM Interop
    Last Post: 2009-09-25, 03:55 PM
  5. DIMENTION
    By kofiasem in forum AutoCAD Annotation
    Last Post: 2009-04-17, 03:17 PM
