Intuitive ViewCube Off
Summary: Add a "Turn ViewCube Off" option to ViewCube Settings.
Description: I never use the view cube and it was getting in my way, so I wanted to turn it off. Right clicking on the view cube gets you to the "ViewCube Settings" dialog box but there is no way to turn it off from there. I googled it and found out that you have to go to Options and uncheck the "2D Wireframe visual style" on the 3D Modeling tab, or, you could go to the "View" ribbon, and turn it off in "Viewport Tools" (I wanted it off in the model). Adding a simple check box to ViewCube Settings would be an easy fix and make it more intuitive.
Product and Feature: AutoCAD - 3D
Submitted By: kayak on 09/14/2016
Re: Intuitive ViewCube Off
Description: I never use the view cube and it was getting in my way, so I wanted to turn it off. Right clicking on the view cube gets you to the "ViewCube Settings" dialog box but there is no way to turn it off from there. I googled it and found out that you have to go to Options and uncheck the "2D Wireframe visual style" (what?) on the 3D Modeling tab, or, you could go to the "View" ribbon, and turn it off in "Viewport Tools" (I wanted it off in the model). Adding a simple check box to ViewCube Settings would be an easy fix and make it more intuitive.
Product and Feature: AutoCAD - User Interface
Used to be a pain on older versions, not sure what version you're using now. I can now control it in Options on the 3D Modeling tab unchecking options under Display the ViewCube, in the Ribbon, on the Navigation Bar, in the Viewport Controls, or by setting the NavVCubeDisplay system variable in acaddoc.lsp.
Agreed that there are numerous ways to kill the viewcube, but the one place that makes the most rational sense would be right-clicking and settings. Then again, I've not noticed Autodesk embracing rationality lately..
This wish has been reported as granted and already in the software.
- You may not post replies
- You may not edit your posts
Forum Rules
