Thread: Having Troubles Creating Flat Pattern
    2016-09
    Default Having Troubles Creating Flat Pattern
    I am a student working on a school, club project on Inventor 16'. My club is creating a grill that looks like a football helmet. I have a model of the grill as a sheet metal file, however I can't get the flat pattern to work correctly. This may be due to the fact that I started the project as a regular IPT and converted the project into a sheet metal file; consequently there are no physical bends. Do you need bends in order to make a flat pattern? Thank you for your time and advise.
    2012-06
    28
    Default Re: Having Troubles Creating Flat Pattern
    I looks like you are trying to make a flat pattern out of a double curved item. Basically Inventor can't create a flat pattern out of a double curved surface. You need serious sheetmetal software to create a deep draw flat pattern.
    Otherwise provide a screenshot of your model or the part itself for further investigation.
    Rob.
    2015-08
    Eastern Iowa
    87
    Yes, in my experience you need bends to create a flat pattern. What you have may possibly work as a molded part or casting, but not as a sheetmetal part. It won't make the flat pattern. Inventor has difficulty with continuous curves such as what your are describing.
    2010-10
    Crazy question (only because I have been victim myself)... Do you have the sheet metal Defaults set correctly?
  1. Flat Pattern Modification
    Last Post: 2012-08-31, 03:48 AM
  2. 2011: Creating flat pattern of tube end profiles with frame generator
    By dcook87725927 in forum Inventor - General
    Last Post: 2011-05-25, 06:21 PM
  3. Flat Pattern
    By BeKirra in forum Inventor - General
    Last Post: 2009-10-22, 04:40 AM
  4. Derived Flat Pattern
    Last Post: 2008-02-08, 04:08 AM
  5. Flat Pattern a Helix
    Last Post: 2006-11-22, 04:50 AM
