Thread: Adjust Pivot origin by Pivot, Object or Hierarchy
    2008-09
    Nebraska & Iowa
    378
    Default Adjust Pivot origin by Pivot, Object or Hierarchy
    Just wanted to post a tip for new users to 3dsMax. I've noticed that sometimes when I bring in geometry from other programs like Revit or Sketchup, the object's origin point (i.e. where the pivot handle is) shows up in wildly different locations. To correct this, I've posted a couple screen shots on where to go and what to do to return these values back to the center of the object, OR to place it wherever you need it to be.
    Click on the Object you want to adjust the "handle" on. Handle referring to the grip you use to manipulate the object's position, scale or rotation.
    In the Hierarchy tab view the options for Adjusting Pivot.
    Click on option you desire to adjust where that handle is located.
    Adjust as needed. Use snaps or the alignment tool below.
    That's it! I've found this very helpful when rotating certain objects and when I need that rotation point to be on the end and not the center of the object.
    Default Re: Adjust Pivot origin by Pivot, Object or Hierarchy
    Interesting points. Thanks for sharing.
  1. Full Height & pivot doors
    By Alex Page in forum Revit Architecture - Families
    Last Post: 2020-11-05, 03:13 PM
  2. Redimensionnement d'objet sur 3ds max et point de pivot
    By frankypop in forum 3ds Max - General
    Last Post: 2014-06-24, 07:34 AM
  3. Pivot Ball
    By craigf.56714 in forum AutoCAD 3D (2007 and above)
    Last Post: 2011-06-07, 07:49 AM
  4. Point pivot
    By batproj in forum 3ds Max - General
    Last Post: 2010-11-01, 11:41 AM
  5. concerning pivot
    By jiaoyanbing in forum Revit Architecture - General
    Last Post: 2005-03-17, 01:07 PM
