Dear Masters,
I have one Lisp, with help of my existing lisp generating notepad file. i need CSV file format instead of notepad as a shown image format.
Kindly make a modification in my existing Lisp.
;; gc:distinct (gilles chanteau)
;; Suprime tous les doublons d'une liste
;; Argument
;; l : une liste
(defun gc:distinct (l)
(if l
(cons (car l) (gc:distinct (vl-remove (car l) l)))
(defun l-coor2l-pt (lst flag / )
(if lst
(cons
(list
(car lst)
(cadr lst)
(if flag
(+ (if (vlax-property-available-p ename 'Elevation) (vlax-get ename 'Elevation) 0.0) (caddr lst))
(l-coor2l-pt (if flag (cdddr lst) (cddr lst)) flag)
(defun c:ptdef2notepad ( / js dxf_cod mod_sel n lremov str_sep oldim ename l_pt l_pr pr l_x l_y tmp1 f_openx tmp2 f_openy)
(princ "\nSelect model object for filtering: ")
(while
(null
(setq js
(ssget "_+.:E:S"
(list
'(0 . "*LINE,POINT,ARC,CIRCLE,ELLIPSE,INSERT")
(cons 67 (if (eq (getvar "CVPORT") 1) 1 0))
(cons 410 (if (eq (getvar "CVPORT") 1) (getvar "CTAB") "Model"))
(princ "\nIsn't an available object!")
(vl-load-com)
(setq dxf_cod (entget (ssname js 0)))
(foreach m (foreach n dxf_cod (if (not (member (car n) '(0 67 410 8 6 62 48 420 70))) (setq lremov (cons (car n) lremov))))
(setq dxf_cod (vl-remove (assoc m dxf_cod) dxf_cod))
(initget "Single All Manual")
(if (eq (setq mod_sel (getkword "\nSelect mode, [Single/All/Manual]<Manual>: ")) "Single")
(setq n -1)
(if (eq mod_sel "All")
(setq js (ssget "_X" dxf_cod) n -1)
(setq js (ssget dxf_cod) n -1)
(setq
str_sep " " ;-> **** YOU CAN CHANGE THIS STRING BY WHAT YOU WONT ! **** <-
oldim (getvar "dimzin")
(setvar "dimzin" 0)
(repeat (sslength js)
(setq ename (vlax-ename->vla-object (ssname js (setq n (1+ n)))))
(setq l_pr (list 'StartPoint 'EndPoint 'Center 'InsertionPoint 'Coordinates 'FitPoints))
(foreach pr l_pr
(if (vlax-property-available-p ename pr)
(setq l_pt
(if (or (eq pr 'Coordinates) (eq pr 'FitPoints))
(append
(if (eq (vla-get-ObjectName ename) "AcDbPolyline")
(l-coor2l-pt (vlax-get ename pr) nil)
(if (and (eq pr 'FitPoints) (zerop (vlax-get ename 'FitTolerance)))
(l-coor2l-pt (vlax-get ename 'ControlPoints) T)
(l-coor2l-pt (vlax-get ename pr) T)
l_pt
(append (l-coor2l-pt (vlax-get ename pr) T) l_pt)
(setq l_x (gc:distinct (mapcar '(lambda (x) (rtos (/ x 1.0) 2 2)) (vl-sort (mapcar 'car l_pt) '<)))) ;-> **** YOU CAN CHANGE UNIT AND PREC (rtos x unit prec) ! **** <-
(setq l_y (gc:distinct (mapcar '(lambda (x) (rtos (/ x 1.0) 2 2)) (vl-sort (mapcar 'cadr l_pt) '<)))) ;-> **** YOU CAN CHANGE UNIT AND PREC (rtos x unit prec) ! **** <-
(setq
tmp1 (vl-filename-mktemp "tmp_x.csv")
f_openx (open tmp1 "w")
(write-line (apply 'strcat (mapcar '(lambda (x) (strcat x str_sep)) l_x)) f_openx)
(close f_openx)
(startapp "notepad" tmp1)
(setq
tmp2 (vl-filename-mktemp "tmp_y.csv")
f_openy (open tmp2 "w")
(write-line (apply 'strcat (mapcar '(lambda (x) (strcat x str_sep)) l_y)) f_openy)
(close f_openy)
(startapp "notepad" tmp2)
(setvar "dimzin" oldim)
(prin1)
Please find sample drawing and sample CSV Format.
Thanking you,
Best regards.
