Thread: Station text export with rotation
    2015-11
    8
    Default Station text export with rotation
    I have station text along an alignment with text oriented perpendicular to the alignmnet. I have tried MAPEXPORT to create shapefiles of the text. When I import back into CAD with MAPIMPORT the text has lost its rotational values and all text is oriented East. Is there a way to have the text maintain the rotational value when importing? Thanks.
    TN/KY Area
    1,640
    Default Re: Station text export with rotation
    When you export to shp format you can select the angle property of the text then after you import do a property query to base the rotation angle on that attribute. Alsodepending on what version of Map3D the rotation angle gets exported automatically if you export the data.
  1. 2013: Export Station Labels
    By JackofAllCAD in forum AutoCAD Civil 3D - Alignments
    Last Post: 2015-08-10, 03:47 PM
  2. Text rotation
    By lee.johnson in forum AutoCAD General
    Last Post: 2011-11-03, 11:45 AM
  3. Text Rotation
    By bosso in forum AutoCAD General
    Last Post: 2007-09-08, 10:52 PM
  4. Seeking Tutorial for creating/editing Station Offset labels and text
    By rdomke69 in forum AutoCAD Civil 3D - General
    Last Post: 2007-01-08, 03:48 PM
  5. text rotation
    By brantf in forum Revit Architecture - General
    Last Post: 2003-05-16, 07:12 PM
Tags for this Thread
