Results 1 to 1 of 1
Thread: Working with OLE (eg Excel) Objects within a drawing file
    13,657
    Default Working with OLE (eg Excel) Objects within a drawing file
    Experiencing issues / problems with OLE (eg Excel) Objects within a drawing file, the below information might just help resolve such issues / problems....
    Links:
    Autodesk Knowledge Base:
    ID: TS21115 - OLE defined
    ID: TS21721 - Modify properties of OLE object
    ID: TS76460 - Requirements to copy or paste Microsoft Excel OLE objects
    ID: TS17397 - Microsoft® Excel spreadsheets is truncated when pasted into drawing
    ID: TS21203 - Control visibility of OLE objects
    ID: TS21730 - Limitations of using OLE objects
    ID: TS17736 - Pasting OLE objects as AutoCAD® objects
    ID: TS72985 - OLE object does not update in AutoCAD® when source document is saved
    ID: TS21095 - Updating OLE links in a drawing
    ID: TS74385 - Linked Microsoft Excel spreadsheet is not displayed correctly
    ID: TS59829 - AutoCAD Entities option not listed in Paste Special dialog box
    ID: TS1059077 - Rotating OLE objects
    AUGI Forum:
    Open a DWG with a MS Excel OLE, it somehow truncates the embedded text.
    Excel OLE always comes in at the same size and is very large
    Inserting OLEs from Excel into AutoCAD 2004, each one comes in a different scale
    inserting Excel file
    Change to excel docs
    Sizing and OLE Object window in AutoCAD
    ACAD 2004 OLE OBJECTS
    OLESCALE command not working
    Excel Spreadsheet wrong size insert & Linking
    CAD 2005 and Excel
    Random rows appear in OLE object
    Autocad 2005 & Excel files. (.xls)
    Insert Excel into AutoCAD
    An active link (Excel OLE)
    Importing Excel 97 to Autocad 2005
    Controlling OLE point size
    Insert Excel spreadsheet only half shows up
    Excel speadsheet limit of proportion as OLE object
    Update / Add data in linked Excel Sheets so it automatically updates in AutoCAD
    OLE Word 2000 modified with Word 2003 causes formatting problems
    AutoCAD LT 2007 - OLE Objects not shown fully
    Linking a Word document into AutoCAD 2007 DWG file
  1. Import points into drawing file from Excel
    By msanders.85217 in forum AutoCAD Civil 3D - General
    Last Post: 2013-07-16, 11:41 AM
  2. OLE (eg Excel) Objects within drawing file not Plotting correctly
    By Mike.Perry in forum AutoCAD FAQ (Read only)
    Last Post: 2013-01-21, 02:27 PM
  3. Replies: 22
    Last Post: 2006-07-27, 08:15 PM
  4. Replies: 2
    Last Post: 2006-05-02, 04:41 PM
  5. Unable to select OLE (eg Excel) Objects within drawing file
    Last Post: 2005-03-26, 07:05 PM
