Results 1 to 1 of 1
Thread: Mouse middle button (wheel) playing you up
    13,656
    Default Mouse middle button (wheel) playing you up
    Experiencing issues / problems with your mouse middle button (wheel) ie.
    Can't Pan.
    Can't Zoom.
    OSnap menu not displaying.
    etc.
    The below information might just help resolve such issues / problems....
    Links:
    Autodesk Knowledge Base:
    ID: TP2490728 - Side Button Mouse Customization for the OSNAP Menu
    ID: TS71373 - Set mouse thumb button to open object snap menu
    ID: TS69028 - Activate object snap menu from Microsoft IntelliMouse Explorer mouse
    ID: TS74883 - Wheel mouse zooms or scrolls drawing window when text window is active
    ID: TS72578 - Unable to zoom using mouse wheel
    ID: TS45716 - Zooming with Logitech Wheel Mouse
    ID: TS84054 - Cannot pan or zoom using IntelliMouse wheel button
    ID: TS17268 - Enable and disable real-time pan on middle button of three-button mouse
    ID: TS65759 - Wheel button on mouse does not perform zoom functions
    ID: TS19115 - Adjusting zoom percentage and scroll value for the mouse wheel
    ID: TS22795 - Cannot pan or zoom with mouse wheel
    ID: TS76296 - Mouse wheel not zooming
    ID: TS26915 - Using Joystick mode with a wheel mouse
    ID: TS20605 - Wheel mouse panning function is not started
    ID: TP5147130 - Using ZOOMFACTOR
    AUGI Forum:
    Scroll Button Pan is Wacky!
    Middle Button OSNAP?
    Middle Button option on mice?
    not able to use my favorite commands!
    Panning with mouse wheel
    Logitech mouse and CAD
    Intellimouse Middle Wheel Button
    Middle mouse button zoom-pan
    Can't Zoom Pan with Logitech MX 1000 in Acad
    Unable to Pan using the wheel button on my mouse
    Panning with the middle mouse button
    Pan not working with mouse wheel
    Pan button problem
    Can't 'middle button pan' when all seems set right
    Pan wheel function on Intellimouse
    changing mouse buttons
    using scrollwheel mouse
    Wheel Mouse button not Pan Realtime
    osnap shortcut in AcadLT 2002
    Panning with wheel mouse button
    Assign Middle button to OSNAPS
    Wheel mouse does not Zoom
    Middle mouse button has stopped working
    Wheel Mouse button trouble
    Need help with middle button/wheel...
    Mouse wheel does not Pan
    Middle mouse button won't Pan
    Panning with Middle Mouse is Mirrored.
    Real-time Pan with mouse-wheel, pans in joystick style
    Can't set-up scroll button on mouse to work correctly - Pans but does not Zoom
    Middle mouse wheel button not panning
    Wheel mouse button does not pan?
    AutoCAD 2007 unable to Pan using the mouse middle button
    AutoCAD 2007 Pan not working via IntelliMouse middle button
    AutoCAD 2007 setting up mouse wheel and button allocations
    Logitech MX500 optical mouse - wheel does not Pan
    Logitech mouse not panning properly
    AutoCAD 2008 - Middle button on mouse not panning
    Unable to pan with the middle mouse button
    Middle button (Wheel) not Zooming on 64 bit system?
    Last edited by Mike.Perry; 2007-06-19 at 10:25 AM. Reason: Additional information added.
  1. Replies: 1
    Last Post: 2013-11-19, 07:33 PM
  2. Intellimouse Middle Wheel Button
    By d.w.smith in forum AutoCAD General
    Last Post: 2009-03-02, 09:20 AM
  3. Middle mouse wheel button not panning
    By Maverick91 in forum AutoCAD General
    Last Post: 2006-05-23, 08:33 PM
  4. Need help with middle button/wheel...
    By cnenninger in forum AutoCAD General
    Last Post: 2006-01-26, 08:52 PM
  5. Mouse right click button playing you up
    By Mike.Perry in forum AutoCAD FAQ (Read only)
    Last Post: 2005-03-27, 01:42 AM
