Thread: Automated Text - New Line when Comma
    Default Automated Text - New Line when Comma
    Hello,
    I have an address listed at the top of a paperspace, in a linear fashion, separated with commas.
    I also have the same multi-line address stated in my titleblock.
    Is it possible to make the multi-line text update to display the information in the single line text, but a comma would dictate a new line?
    Example:
    20 Deans Yard, Westminster, London, SW1P 3PA
    displayed as
    20 Deans Yard
    Westminster
    London
    SW1P 3PA
    Cairo - no, not Illinois
    4,761
    Default Re: Automated Text - New Line when Comma
    sorry, I don't believe that's possible.
    What you can do, is add that to DWGPROPS, with linefeeds as desired, in the Comments section, and then link your field to that. AFAIK, that's the only place that linefeeds/carriages returns are recognized.
    2015-10
    Central New Jersey
    403
    I'd do it as 4 separate fields. The multi-line at the top of the sheet would assemble them horizontally with a comma between and the title block would do it in a vertical fashion without the commas.
    Where is the address information coming from? (as in, what do the fields point to for this information)
    Tallahassee, FL
    3,252
    Using the Express Tool PROPULATE you could create and use a template with four Custom Drawing Properties that you could reference as fields formatted in line with commas at the top and on seperate lines elsewhere.
    Tom Beauford P.S.M. - Civil 2019 on Windows 10 Enterprise
    Ph# (850)606-1516 Home Page
  1. change a text in table 1 and automated modifi in table 2
    By bbogc694889 in forum AutoCAD Fields
    Last Post: 2015-04-20, 02:35 PM
  2. Automated Trim/Break at a specified dist for a Line
    By ameador in forum AMEP General
    Last Post: 2009-08-07, 03:17 PM
  3. Replies: 0
    Last Post: 2008-12-11, 07:27 AM
  4. Convert single line text to multi line text?
    By civilguy in forum AutoCAD General
    Last Post: 2006-10-11, 11:37 PM
  5. Adding comma's to a text box...
    By mike_atwell in forum VBA/COM Interop
    Last Post: 2006-03-22, 03:50 PM
