Thread: ramp cutoff in plan
    2016-02
    DE/MD
    185
    Default ramp cutoff in plan
    is there a way to change the way a ramp (sloped floor) gets cutoff above the cut plane?
    thanks.
    2005-06
    in the upper right corner
    3,495
    Default Re: ramp cutoff in plan
    Quote Originally Posted by htlmv View Post
    thanks.
    Not sure what you mean, can you post a screen shot and more information?
    (you may get better help, at the time I'm reading this, there were 70 views and no replies)
    You want it not to cut?
    you want it to appear different when cut?
    2 things come to mind are "view range:" top of view/cut plane extents and "Depth Clipping" options...
    2015-08
    199
    In your view go to VG settings and in the model tab look for ramps and then expand to see the different parts you can control. There is one called ramps beyond cut line. You can control what the ramp looks like above the cut plane there.
    2005-06
    3,495
    Quote Originally Posted by marmiketin View Post
    Cool, nice tip!
    2023-06
    Hi, i got here as this topic was the more close to what is making me spend all day without a solution. For the ramps, thanks to you i got to know where lines above cut plane can be shown/controled. But in case of a sloped building pad, also tried with a sloped floor, that option doesn't exists, so i can't find a way to show the portion above cut plane, preferably with dashed/hidden lines. That portion doesn't even appear in wireframe mode or underlay, so i could try the linework tool. Hope to get help. Thanks in advance.
  1. 2011: Ramp not cut in plan
    By damon.sidel in forum Revit Architecture - General
    Last Post: 2011-10-27, 08:38 PM
  2. RAMP NOT SHOWING IN PLAN
    By double_u_d in forum Revit Structure - General
    Last Post: 2010-10-14, 08:37 PM
  3. Ramp view in plan
    By nextvkin in forum Revit Architecture - General
    Last Post: 2008-06-05, 10:09 AM
  4. Roof Cutoff level
    By Chris DiSunno in forum Revit Architecture - General
    Last Post: 2007-11-26, 02:53 AM
  5. Ramp Spot Elevations in plan view
    By tarch in forum Revit Architecture - General
    Last Post: 2007-09-27, 04:11 AM
