It's not the best programming (see my suggestion following it), but the exact answer to your question is:
(setq second (eval(read first)))
Here's better programming (Use LISt Processing since this is LISP):
(setq vars (list (list "1" 12345)(list "2" 56789)(list "3" 10101)))
(initget 1 "1 2 3")(setq first (getkword "\nSpecify a variable [1/2/3]: "))
(setq second (cadr (assoc first vars)))
Let me know if that doesn't make sense or does not do what you need.
Tom
mattko
I'm having trouble with referring to a variable value by string. Searched a few hours, no luck.
Example:
(setq var1 12345)
(setq var2 56789)
(setq var3 10101)
Input a string and store it to a variable:
(setq first (getstring)) lets say "var2"
Set the value of the second variable based on the provided string.
(setq second (somethingsomething first))
>>> 56789
