Thread: How to customize field expression
    Default How to customize field expression
    Is there a way to customize the display format of custom property. For example I have a custom property named part_no with a 13 Digit value 1234567890123.
    In the title block I would like the value to show up with blanks in order to enhande legibility. Example: 1 234 56 78 90 123
    Any help would be great
    Earth
    9,803
    Default Re: How to customize field expression
    No as far as I know, w/o customization.
    So you can't just store the property as 1 234 56 78 90 123 ?
    R.K. McSwain | CAD Panacea |
    No, the number is propagated to a DB and should not Change - only the representation
    2015-10
    Central New Jersey
    439
    Could you give us a little more insight as to how and where the part number is propagated?
    Sometimes you can perform some functions on numbers to extract certain place values. Example: Start with 1234, divide it by 100, results in 12.34, format it as a decimal number with a space instead of a ".", results in 12 34. Or, truncate the 12.34 result for a result of 12. Multiply that result by 100 to get 1200, then subtract that from the original 1234 for a result of 34. It would take several carefully crafted field formulas.
    2001-07
    319
    number to string (itoa)
    string to list (vl-string->list)
    reverser list
    pattern add space. (ascii " ") -> add to list
    caracter to string (chr) -> list
    reverse the new list.
  1. Field Diesel Expression for LT to bring up last layout
    By Darren Allen in forum AutoLISP
    Last Post: 2016-06-17, 02:18 AM
  2. read field expression of an attribute
    By alberto.boffi695984 in forum AutoLISP
    Last Post: 2011-06-02, 07:29 AM
  3. Customizing field expression
    By amarkovi in forum Dynamic Blocks - Technical
    Last Post: 2009-03-31, 06:00 PM
  4. Field expression change
    By csiress in forum AutoCAD Fields
    Last Post: 2007-11-20, 06:37 PM
  5. Replies: 1
    Last Post: 2007-06-06, 05:50 PM
