Thread: Disappearing Viewport
    2017-03
    Default Disappearing Viewport
    Does anyone have this situation? If I draw a viewport with a dashed line type it won't show up on the pdf. It is not on a frozen layer or a non-plot layer. Everything looks good on paperspace but when I print to pdf nothing is there. Change to a continuous linetype and it works.
    2001-12
    St. Louis
    5,407
    Default Re: Disappearing Viewport
    Quote Originally Posted by RobinASteiger744698 View Post
    which software package and version?
    Melanie Stone
    @MistresDorkness
    Technical Editor
    2021-04
    Same here. Anyone has a resolution for that problem?
    2001-12
    St. Louis
    5,407
    Moved from the LUG forum to this one, as I believe it will be better served here.
    Melanie Stone
    @MistresDorkness
    Technical Editor
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Standard behavior I believe.
    There are easy workarounds like viewports from objects that have linetypes. https://forums.autodesk.com/t5/autoc...997454#M991707
    You could also set the viewport layer to NoPlot, Off, or Frozen and draw the viewport outline as a polyline on another layer as a dashed line.
    I never plot viewport borders, I draw whatever borders I need setting their lineweights thinner than sheet boundaries.
  1. Replies: 2
    Last Post: 2017-08-09, 01:04 PM
  2. Replies: 1
    Last Post: 2014-11-04, 03:32 PM
  3. 2013: Disappearing Viewport! Please help!
    By lhuynh930530 in forum AutoCAD General
    Last Post: 2013-03-27, 11:40 PM
  4. 2010: disappearing viewport
    By sc_recycle in forum AutoCAD General
    Last Post: 2011-08-01, 08:00 PM
  5. Smaller Viewport to hide / mask part of a larger Viewport
    By thomas.stright in forum AutoCAD General
    Last Post: 2006-04-05, 11:03 PM
