Thread: Changing width and height in block attribute into several drawings
    2017-03
    3
    Wink Changing width and height in block attribute into several drawings
    Hi there
    I m looking for a lisp to change width and height into several drawings, without entering in all of them.
    If you have any idea
    Thank you
    All AUGI, all the time Tharwat's Avatar
    2010-06
    922
    Default Re: Changing width and height in block attribute into several drawings
    Hi,
    Yes that is possible if you are manually selecting attributed blocks but with several drawings and without opening them, that might need too much codes to get the job done as required.
  1. Attribute Height/Width Modification
    By LSElite in forum AutoLISP
    Last Post: 2013-06-02, 11:18 PM
  2. Changing attribute tags in multiple drawings
    By caburke in forum AutoCAD General
    Last Post: 2012-05-01, 05:10 PM
  3. Changing block attribute layer globally
    By jalayna.245389 in forum AutoCAD LT - General
    Last Post: 2010-05-12, 02:06 PM
  4. Changing Block Height & Width
    By lee.johnson in forum AutoLISP
    Last Post: 2010-02-18, 06:36 PM
  5. LISP FOR CHANGING TAG NAME IN BLOCK ATTRIBUTE
    By drsvsmani in forum AutoLISP
    Last Post: 2008-05-06, 06:42 PM
Tags for this Thread
