Thread: 00# Sheet Numbers as #
    2015-10
    Central New Jersey
    439
    Default 00# Sheet Numbers as #
    My usual process with drawing sets is to print them to a PDF file for each sheet. Those PDFs derive their name from the SSM as the sheet number followed by the sheet title. The sort order in the folder of the PDFs is based on the leading number of the PDF name and sorts fine up to 9 but then goes to 1, 10, 11 .... 2, 20, 21 and so on. If I numbered the sheets 01, 02, 03, my title blocks inherited this as their sheet number from the field that was the default value of the sheet number attribute. I wanted my title blocks to only show 1, 2, 3 ... as their number, and I finally figured it out today. I revised the field, copied its contents and pasted it into a field formula, pressed the 'evaluate' button to enable the Format list, selected Decimal, 0 precision, then Additional Format and chose 'drop leading zeros'.
    Anyway, it finally made the results I wanted. Title blocks show 1, 2, 3 and PDFs get written as 01, 02, 03.
    I thought I'd share it in hopes it might lead someone else to their own solution for a similar need.
    in the upper right corner
    3,508
    Default Re: 00# Sheet Numbers as #
    Nice tip! Thanks for sharing.
    That surely will be useful for some of us.
    2014-12
    4
    Same situation different solution.
    Rather than adjusting the decimal & precision in the formula box we added *1 after the contents and this removed the zero.
    2015-10
    Central New Jersey
    439
    Interesting. I like it.
  1. Revisions and sheet numbers
    By kevin.bell.72378 in forum Revit Platform - Wish List
    Last Post: 2013-06-29, 02:46 PM
  2. Automatically Generate Total Sheet and Total Subset Sheet Numbers
    Last Post: 2009-07-07, 06:02 PM
  3. Sheet numbers for Legends
    By thomasf in forum Revit Architecture - General
    Last Post: 2007-12-23, 06:41 PM
  4. Duplicate Sheet Numbers
    By cdchristian in forum Revit Architecture - General
    Last Post: 2007-06-07, 10:27 PM
  5. Replies: 3
    Last Post: 2006-04-26, 02:35 PM
