Page 6 of 6 FirstFirst ... 23456
Results 51 to 54 of 54
Thread: Civil 3D | High-Performance Workstations
  1. #51
    Programming Moderator BlackBox's Avatar
    5,443
    Default Re: Civil 3D | High-Performance Workstations
    Here's are some sample benchmarks, comparing NVMe/M.2 SSDs & RAM Disks:
    Attachment 106802
    After using this for a few months, here are today's benchmarks:
  2. #52
    2016-11
    5
    Does anyone have suggestions on a Benchmarking Program to rate/grade a PC's ability to handle intensive Civil 3D project files? Something in the realm of .
    I tried . However, I couldn't get the program to display the resulting indexes no matter what I tried. After an hour I decided it wasn't worth the effort because it was only testing three dimension drawings in regular AutoCAD and I felt that a mature Civil 3D project file would create greater, and different, demands on the system than say a simple three-dimensional steering wheel.
  3. #53
    5,443
    Quote Originally Posted by lmessal738905 View Post
    Have you tried Cadalyst's C2015?
    https://www.cadalyst.com/benchmark-test
    Not sure of any alternative to this, but can tell you that in running C2015 recently to gauge some recent changes I've made to my setup, the scores it rated were slightly lower than before the changes were made, but the actual performance I'm seeing in Civil 3D (i.e., times for drawing open/save, surface/corridor rebuild, export drawing, etc) have all improved when using my own benchmark tools (not to mention the user 'feel' of the UI/palette/ribbon responsiveness).
    The above-linked test might be useful for some things, but you're always better off running your own benchmark tests for the specific areas you're wanting to improve, IMHO.
    Cheers
  4. #54
    5,443
    After some recent tweaks, here are today's benchmarks (+/- 6% increase):
    [Edit] - I should note that this is without RAID.
  1. ED319-1: High Performance Buildings for Higher Education
    By Autodesk University in forum Education
    Last Post: 2015-08-07, 05:30 PM
  2. High performance for surface modeling
    Last Post: 2015-07-01, 08:29 AM
  3. CP31-1: High Performance AutoCAD Programming
    Last Post: 2013-04-10, 02:29 AM
  4. GI32-2: High Performance Data Models for Autodesk Map
    By Autodesk University in forum Geospatial
    Last Post: 2013-04-08, 07:51 PM
