Hey guys,
the wipeout frame in this dynamic block plots even though i have the wipeout frame set to "0".
If you have time could someone look at this and tell me what Im missing?
Im using acad 2018, windows 10 pro 64bit
Hey guys,
I couldn't duplicate your problem when plotting to PDF (I used monochrome CTB, I didn't have your plot style)
I'm using Acad 2017, so maybe that's it too?
I did "see" the wipeout line when previewing the plot as a faint gray line, but it didn't print.
Just for giggles I put the wipeout on it's own layer and tried it and didn't see the line in preview.
Thank you Ted for taking the time to look at it. I see the same faint gray line, but it is plotting when I plot. I would love to be able to use wipeout on all my text and in some of my blocks. But, until i can get this working correctly Im stuck fixing lines every time a change is made to my drawings. I have never had luck with wipeout or text masking. This would be a HUGE time saver if I could iron this out.
Thanks again, Ted!
I've never been a fan of Wipeouts -- they always seemed to be more troublesome than useful.. MText and dimension text masking on the other hand, has always been 100% reliable. Is either of those failing for you?
One suggestion -- the the color of the wipeout object/frame to 255,255,255
I agree, dimension text masking, I have had no problems. Masking multi-line text I haven't tried in years.
