Results 1 to 10 of 15
Thread: Can't Rename a Level without crashing the file
    2004-06
    23
    Default Can't Rename a Level without crashing the file
    I have a project that we started in Revit 4 or 5 now we are using 7 so now I have one level that I am trying to rename but I can't the file crashes when I do so all the other levels have been renamed no problem, there is something odd with it to the level shows up blue, so when I double click on it to see what plan is associated with it nothing happens, suggestions?
    AUGI Addict luigi's Avatar
    2015-11
    Royal oak, Michigan
    1,513
    Default Re: Can't Rename a Level without crashing the file
    send the file to support at revit, they will investigate...
    2003-06
    Manchester, NH
    222
    When you are asked if you want to rename the associated view, are you saying yes? If so, try saying no, and then rename the view manually.
    Autodesk Revit Developer
    2004-02
    Waltham
    468
    Generally:
    We have zero tolerance for crashing. So, if you can get Revit to crash (especially when it's reproducible) send everything (such as project and journal files) to Revit Support right away.
    Since crashes are few and far apart, there is not much help you can derive from the forum.
    AUGI Addict Joef's Avatar
    2003-12
    Victoria, BC
    1,273
    I had this exact same problem yesterday. I sent off the file to support. I just this minute received this reply:
    "For your info, I did talk to the software engineer about this crashing problem when renaming the level on the elevation. They will fix this problem in Revit 8.0.
    For Revit 7.0, as workaround when you rename the Level, Revit will also ask you "Would you like to rename corresponding views?", you should select "NO". By doing so, Revit shouldn't crash. Then you can go to the Project Browser to rename manually the corresponding Plan view as the same name of your Level."
    Unfortunately this is not a very satisfactory answer as the program crashes before Revit gets a chance to ask any questions. It also does not apply if there is no corresponding view to alter in the project browser.
    2004-02
    Waltham
    468
    Grab the 8.0.
    AUGI Addict Scott Hopkins's Avatar
    2003-05
    Santa Barbara, CA
    1,197
    Quote Originally Posted by FK
    Few and far apart - Thats a good one!
    All AUGI, all the time ajayholland's Avatar
    2003-04
    Sunny Southern California
    505
    Grab the 8.0.
    We also had this problem on a current project that was started in V6.1. I’m happy to know that this has been fixed in V8.
    ~AJH
    A. Jay Holland
    Former Co-Chairperson - South Coast Revit Users Group
    Independent Revit Consultant
    BIM Mentors
    ____________________________________
    Nothing Real Can Be Threatened, Nothing Unreal Exists
    I could stop if I wanted to Paul Monsef's Avatar
    2003-09
    Everett, WA
    351
    Grab the 8.0.
    Grab it when??
    Paul Monsef
    Everett, Washington
    http://www.monsefdesign.com
    2004-02
    Waltham
    468
    If I'm not hallucinating it's beta (so many releases my head is spinning). Beta is comparable to past Web releases, it should be quite stable. In this case, more stable than 7.
    Edit: there is no 7.1.
  1. Rename File from SSM?
    By dyroff in forum AutoCAD Sheet Set Manager
    Last Post: 2008-11-05, 03:26 AM
  2. Missing Sheet / Rename Level
    By mitch.122376 in forum Revit Architecture - General
    Last Post: 2007-02-14, 06:53 PM
  3. Rename a Central File
    By nsinha73 in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2006-10-18, 11:59 PM
  4. Open a Russian DWG file without having to rename it to English?
    By chris.kulhanek in forum AutoCAD General
    Last Post: 2006-07-19, 07:26 PM
  5. I had to rename the help file(acad.chm) to use it.
    By Borg in forum AutoCAD General
    Last Post: 2004-11-02, 05:22 PM
