Results 1 to 7 of 7
Thread: Shorthand commands changed
    2009-04
    26
    Default Shorthand commands changed
    Hello,
    All of the sudden the shorthand commands changed. Li is now line instead of list. X is xref instead of explode. This is on a desktop and is AutoCAD LT 2018.
    thanks,
    in the upper right corner
    3,508
    Default Re: Shorthand commands changed
    Quote Originally Posted by sc_recycle View Post
    Hello,
    thanks,
    Sounds like a custom PGP file has been loaded into your session. (I assume LT uses PGP files).
    The PGP file is where your alias' are for AutoCAD, and many people customize them for their use.
    2009-04
    26
    No one did that on purpose or knows how to do that, so not sure how it happened~! How do I get back the standard one? Thanks!
    Tallahassee, FL USA
    3,667
    Easiest way would be to copy the acad.pgp file from another PC that has the correct shortcuts. The one in my Civil 3D 2018 is dated 9/15/2014, they're not version specific and are rarely modified.
    9,805
    FYI: For AutoCAD LT, the file is named acadlt.pgp
    See also
    2009-04
    26
    Thank you for your information. I copied these files and then they showed that they were already in there. I looked again, and basically, only 9 gradient circle hatches show up and one user hatch. I compared the hatch command and bhatch command on the laptop where it works and all the hatches appear and on the desktop where somehow only these 10 appear. I am using the same command and I copied the .pgp file from the laptop where they are correct and it still doesn't work. hmm?
    - - - Updated - - -
    Sorry that was for the hatch post, but, I did copy that file as well over and didn't change things either. ugh.
    9,805
    @sr_recycle - did you read the link I posted?
    Did you try the GUI method of viewing/editing the PGP file?
    AutoCAD (and AutoCAD LT) will read/load the first .PGP file it finds, based on the current path, and the support file search path.
    Maybe yours is reading a different PGP file, than the one you are viewing/editing.
  1. 2015: Something Changed!!!!!!
    By MikeJarosz in forum Revit Architecture - General
    Last Post: 2015-04-08, 09:30 PM
  2. 2012: Colors Changed, what the ???
    By dsw98 in forum Revit Architecture - General
    Last Post: 2013-03-02, 12:38 AM
  3. language changed
    By lalit_jangid in forum Inventor - General
    Last Post: 2009-05-24, 06:55 AM
  4. Hot Key Commands Vs Selecting Toolbar Commands.
    By matthew.113087 in forum AutoCAD General
    Last Post: 2007-06-28, 11:37 AM
  5. Have dwf & pdf writer changed for 7.0?
    By kimheaver in forum Revit Architecture - General
    Last Post: 2004-10-29, 01:38 PM
