Thread: Selecting Objects
    2003-08
    Tijuana
    225
    Default Selecting Objects
    Hi,
    I am new to Navisworks, and am using Simulate 2017 to inspect a NWD with clashes saved as view points. When trying to select an object to identify it, there are usually intervening objects, which make difficult the selection of objects beyond. Is there an easy way to select an object in a clash to see its properties?
    Carlos Sifuentes
    BIM/VDC Management Brian Myers's Avatar
    2003-02
    St Louis, Missouri
    1,815
    Default Re: Selecting Objects
    Quite a few ways, actually. The easiest way for this conversation is to try to click an object. If another object selects instead, right click, and hide the selected object. It's pretty rare when more than 2 or 3 things are in your way.
    If this bothers you, and you have multiple models, hide the entire model that is in your way (such as the architectural model when selecting MEP items). If it isn't on the screen, you will not be able to accidentally select it.
    Even back in my AutoCAD days I was a fan of what I call the brute force approach. If it gets in your way, turn it off and keep on going if that's faster than elegantly selecting, tabbing, or whatever that program requires you to otherwise do.
    Brian Myers
    Jacobs: VDC Design Office Lead (BIM Leadership)
    Visit my LinkedIn Profile for more information.
    2015-12
    2,095
    My usual process is to ensure the "focus" is on the object(s) in question, then pivot the view around until I can get a clear view. Under extreme circumstances, I will first select the objects then do a "hide unselected", re-orient, then reverse the hide to get everything back. When that's the result of clash check and not immediately obvious I'll update the saved view in Manage with redlines.
    If you are going to fly by the seat of your pants, expect friction burns.
    Some say beauty is in the eye of the Beholder... perhaps so, but I've only seen the disintegration beam.
    Everyone else being wrong is not the same thing as being right.
  1. 2016: Selecting objects
    By patricia.mclish677508 in forum AutoCAD LT - General
    Last Post: 2015-09-21, 08:18 PM
  2. Selecting Objects
    By Gatchy in forum Ecotect Analysis
    Last Post: 2010-06-11, 03:38 AM
  3. Selecting objects
    By dmris300 in forum ACA General
    Last Post: 2006-10-27, 08:21 AM
  4. Selecting objects
    By jason907238 in forum VBA/COM Interop
    Last Post: 2005-06-21, 03:05 PM
  5. I need help selecting objects
    By BARRY.FERGUSON in forum AutoCAD General
    Last Post: 2004-10-12, 12:37 PM
