Thread: Occupancy Sensors as Lighting Control
    2017-08
    2
    Default Occupancy Sensors as Lighting Control
    Is there a way to get my ceiling-mount occupancy sensors to behave as the main light switch for the selected fixtures? As in, most rooms have wall mount combo switch-sensors, so they connect perfectly to the light fixtures as a switch system. I cannot get the same thing to happen for plain old ceiling mount sensors without a physical switch someone would press upon entering or exiting the system. I have already tried to edit the ceiling mount sensor's family to make it a lighting fixture, but I still cannot create switch systems for them.
    Any help would be greatly appreciated-- our office has promised the client we'll do this entire building in Revit and I'm stuck on lighting already.
    2015-11
    Saint Louis, MO
    485
    Default Re: Occupancy Sensors as Lighting Control
    you want the ceiling occ sensor family to be a Lighting Device category. then it will function the same as a wall switch, and you'll be able to assign a Switch ID to it and connect it to a group of fixtures as it's switch.
    hth,
    mike
    2017-08
    2
    Thank you! I had to change the family type to Lighting Device and the part type (under parameters) to "switch," THEN it worked.
  1. 2016: Revit Lighting Control - modular wiring/ Dali addresses
    By daniel.cosgrove625307 in forum Revit MEP - General
    Last Post: 2017-01-04, 10:48 AM
  2. 2016: Lighting Control Panel Schedule
    By gapleb720420 in forum Revit MEP - General
    Last Post: 2017-01-03, 12:55 AM
  3. DV21-1: Autodesk VIZ Lighting: Critical Control
    By Autodesk University in forum Design Visualization
    Last Post: 2013-04-17, 04:18 AM
  4. Occupancy Sensors and Interference
    By badcowboy in forum Revit MEP - General
    Last Post: 2009-03-05, 10:42 PM
  5. how to control lighting on/off settings in linked files
    By mark.98140 in forum Revit - Rendering
    Last Post: 2008-11-05, 07:51 AM
Tags for this Thread
