There seems to be a bug(?) when you use a field to display the value (in a table for example) of an object tag from a block which has annotation scales added to it. I assume because the name is effectively there more than one. The name does appear in the field in the first instance but after saving/exiting and then opening again I end up with ### i.e. “The object referenced by the field is not a valid object”.
Anyone else confirm this? Taking other properties from blocks with annotation scales are fine e.g. position x, y, z.
