Thread: Expression for Angle of Deflection in Label?
    2017-06
    12
    Default Expression for Angle of Deflection in Label?
    I'm trying to create an expression to calc angle of deflection on an alignment.
    I've never written a expression before so I'm not sure where I'm going wrong, but at this point I've frustrated myself to the point that I can't even logically work through.
    I tried the formula ATAN2({PI Northing},{PI Easting}) and formatted the result as angle.
    Has anyone had any luck with this?
    My apologies if this is an overly simple question, I think I've worked myself into a stupor over this.
    Thanks in advance
    Last edited by hannac25; 2017-09-06 at 10:14 PM. Reason: forgot to include the formula
    2015-10
    Central New Jersey
    414
    Default Re: Expression for Angle of Deflection in Label?
    Try this:
    Select the alignment, select Add Labels in the ribbon to open its menu, select Multiple Point of Intersection. This will label all the PIs of the selected alignment with a Point of Intersection label. This label entity has Delta Angle available as a property for labeling.
  1. Angle of Deflection needed on Fittings
    Last Post: 2015-04-07, 03:49 PM
  2. Pipe Label with mask & block using expression
    By nelson in forum AutoCAD Civil 3D - General
    Last Post: 2010-04-15, 12:07 PM
  3. Area Label Expression Length
    By eleonard in forum AutoCAD Civil 3D - Parcels
    Last Post: 2008-07-25, 07:28 PM
  4. Geometry Point options - Angle of Deflection (Delta)
    Last Post: 2007-09-17, 08:10 PM
  5. Label Angle Parameter
    By jspartz in forum Revit Architecture - Families
    Last Post: 2007-02-23, 10:45 PM
