Thread: SPLIT VIEWS
    2004-06
    Slidell, Louisiana
    772
    Default SPLIT VIEWS
    I've seen where you can create manual split profiles by copying the profile as many times as needed and then adjusting each one's station range to what is required.
    However, it seems when you do that, it creates multiple copies of the profile in all of the profiles. I don't know if this is a profile except that if you have to make any changes,
    you'd have to change all of them in each profile.
    has anyone else experienced this? or is there something i am doing wrong?
    I know there is split profile view option to handle this, but the manual copying method seems so simple.
    Robert
    Cairo - no, not Illinois
    4,726
    Default Re: SPLIT VIEWS
    There's only one profile, regardless of the number of profile views is shows up in. Delete it in one PV, and it's gone from all of the, similarly, update in one, and all of them reflect it.
    Not multiple copies, rather multiple instantiations.
    2015-10
    Central New Jersey
    387
    When you copy the profile view, make sure you're only selecting the profile view to copy and nothing else. (don't window the selection)
    2004-06
    Slidell, Louisiana
    772
    Quote Originally Posted by MMccall View Post
    thanks, MMccall, that's exactly what i did, windowed the whole thing. problem solved.
    Robert
    2015-10
    Central New Jersey
    387
    Yea, that copies the profile view and any profiles in the window selection. I've done it before, learned that lesson.
  1. 2015: Call-out split between dependent views
    By slovenc0417 in forum Revit MEP - General
    Last Post: 2016-01-05, 04:39 PM
  2. 2013: Bug with split RCP views?
    Last Post: 2012-11-05, 05:37 PM
  3. Split Views VS. Text
    By Liz437 in forum Revit Architecture - General
    Last Post: 2009-11-11, 02:29 PM
  4. beam system tag split for dependent views
    By crmiller in forum Revit Structure - General
    Last Post: 2009-01-15, 10:17 PM
  5. Break line for split views
    By Chad Smith in forum Revit Architecture - Wish List
    Last Post: 2005-02-28, 09:17 PM
