Thread: AutoLISP 101 - Entity Names - Discussion
    2000-09
    Honolulu Hawaii
    1,028
    Default AutoLISP 101 - Entity Names - Discussion
    Entity Names
    Entities are necessary for manipulating data in drawing files.
    All graphic items (lines, circles, etc...) are entities.
    Useful Entity Functions
    (entlast)
    will return the last graphic entity in a drawing.
    (handent "1C7")
    will return the entity associated with the unique hexadecimal identifier called a handle.
    (entsel)
    will prompt the user to select an object and return a list with two items including the entityname the point selected.
    So...
    (car (entsel))
    will return a selected objects entity name (car returns the first item in a list)
    So to get and store an entityname you use the setq expression.
    (setq entSelection (car (entsel "\nSelect One Item: ")))
    the entsel expression allows for a prompt ("\n" is a carriage return)
    The default prompt is "Select objects:"
    There is also
    (setq entSelectionNested (car (nentsel "\nSelect nested item: ")))
    Which allows the user to select items nested inside other items (like blocks)
    Try it and comment to the discussion thread.
    AutomateCAD
    2002-08
    181
    Default Re: AutoLISP 101 - Entity Names - Discussion
    You can use also (ssname)!
    ((lambda ( / js n)
    (setq js (ssget))
    (cond
    (js
    (repeat (setq n (sslength js))
    (print (ssname js (setq n (1- n))))
    (prin1)
    2000-09
    Honolulu Hawaii
    1,028
    You are absolutely right.
    I have not got to selection sets yet...
    It is on the list.
    I just wanted to make each of these posts relatively short.
    Entity Lists, Tables and Selection are up soon.
    P=
    AutomateCAD
  1. AutoLISP 101 - Loops Discussion
    By peter in forum AutoLISP
    Last Post: 2017-08-04, 04:11 PM
  2. Replies: 18
    Last Post: 2017-07-23, 03:42 AM
  3. AutoLISP 101 - Conditionals - Discussion
    Last Post: 2017-07-01, 09:58 PM
  4. Replies: 0
    Last Post: 2017-06-29, 07:04 PM
  5. Replies: 2
    Last Post: 2017-06-29, 06:02 PM
