View Poll Results: Print Filename Codes
Voters
7. You may not vote on this poll
  • Are a great idea, sign me up
    6 85.71%
  • Would be nice, but not a necessary feature
    0 0%
  • I just wouldn't use
    1 14.29%
Thread: Print Filename codes
    The CADSmith Chad Smith's Avatar
    2003-05
    Brisbane, Australia
    1,731
    Default Print Filename codes
    Currently when we print to a file, there is no way of controlling the file naming for sheets when a sheet set is selected, they come out as 'Drawing Sheet - (Sheet Number) - (Sheet Name)'.
    What I would like is a savable option in the print dialogue that allows me to add a filename convention by using predefined file naming codes, so I don't have to go through and rename the files in Windows Explorer after the set is completed.
    Example codes:
    &P - Project Number
    &C - Client
    &S - Sheet Number
    &N - Sheet Name
    &R - Sheet Revision
    ...etc
    Example filename:
    &P-&S-&R = (Project Number)-(Sheet Number)-(Sheet Revision)
    2003-04
    Scotland
    1,577
    Default Re: Print Filename codes
    If this could be done for DWF it certainly help to convince me to use them over PDF... now that has to help push a wish along Autodesk? - quite a lot thinking about it..... I use third party software for PDF so not sure if it could be implemented for that?
    Press 1 button - print a full set of current DWFs....... sounds like a really good idea to me. Batch DWF plotting for Revit.
  1. Filename without extension
    By joeswantek in forum Inventor - General
    Last Post: 2015-09-17, 11:15 AM
  2. Filepath&FileName Print
    By Ashraf Kpm in forum AutoCAD General
    Last Post: 2010-11-25, 07:13 PM
  3. pdf995 keeps asking for filename
    By JH75 in forum Revit - Plotting/Printing/Exporting
    Last Post: 2008-07-17, 11:06 PM
  4. Parsing a print filename
    By bowlingbrad in forum Revit Architecture - General
    Last Post: 2005-06-27, 10:08 PM
