Thread: Backwards saving a drawing from 2018
    Member Damian_E's Avatar
    2006-07
    Albury, Australia
    49
    Question Backwards saving a drawing from 2018
    Is there an easy way to save a acad2018 created drawing in acad2016, after making changes?
    All I get is a notification that one or more objects can be saved in 2013 format (our base format for saving files) no mention of which objects are incompatible, Purge & Audit have no affect on the drawing.
    2017-02
    6
    Default Re: Backwards saving a drawing from 2018
    In the DWG Trueviewer, You can use 2018foramt DWG to free.
    It can convert DWG format any type.
    2006-07
    Albury, Australia
    49
    The file was saved in the acad2013 format from Acad2018
    Earth
    9,804
    Are you using vanilla AutoCAD or a vertical (such as Civil 3D)?
    With vanilla AutoCAD, SaveAs should do it.
    If the drawing contains elements from a vertical app, especially C3D, then no you can't do this without stripping out those AEC objects.
    Test it by starting a new, no-template drawing in 2018, and saving in 2013 format. Does it work?
    R.K. McSwain | CAD Panacea |
  1. 2018: SAVING DOWN 2018 FILES TO 2017 OR OTHER VERSIONS OF AUTOCAD
    By PINESTONE CADGUY in forum AutoCAD Civil 3D - General
    Last Post: 2017-08-07, 02:26 PM
  2. 2009: Scanning Drawing While Saving/Printing
    By svr_kjg705384 in forum AutoCAD General
    Last Post: 2012-12-13, 06:09 PM
  3. Saving Drawing to the original version.
    By raj_thapar2003 in forum AutoCAD General
    Last Post: 2005-10-12, 05:00 PM
  4. create a dwf while saving a drawing?
    By Doodlemusmaximus in forum AutoCAD Customization
    Last Post: 2005-05-24, 12:30 PM
