Thread: Survey network
    2017-03
    Lisbon. Portugal
    Post Survey network
    Hi I'm a civil engineer creating a template to a survey data collector team.
    They have never used Survey Database in Civil 3D to import data into Civil 3D. So they can't explain me some issues about working with survey database.
    When we want to import a survey data we specify a network. Then we can choose control points, non-control points and setups.
    Do I need to choose it manually, right?
    But what is the purpose?
    Will it be usefull for what?
    Thank you
    2008-12
    New Jersey
    472
    Default Re: Survey network
    Quote Originally Posted by carlosruivo View Post
    Thank you
    Having a database established allows you to store multiple settings based on different types of setups, equipment, description keys, etc.
    The biggest thing along with having a database established is the use of line coding and generating line work when importing in the point files.
    2016-01
    19
    Your first step, to make the job go easier, is find a Surveyor to lead the crew.
  1. Data Reference a Portion of a Pipe Network or Pressure Network
    Last Post: 2013-12-19, 04:09 PM
  2. Snap pipe network object to survey point
    By Mike S in forum AutoCAD Civil 3D - Pipes
    Last Post: 2010-09-15, 12:48 PM
  3. Translate an Individual Network within the Survey Database
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2009-06-29, 04:49 PM
  4. Translate Survey Network
    Last Post: 2009-01-31, 03:01 PM
  5. Replies: 0
    Last Post: 2005-08-30, 06:58 PM
Tags for this Thread
