Results 1 to 10 of 16
Thread: ASCII
    2006-04
    466
    Default ASCII
    I'm bumbed out, all I can do is ASCII for English characters.
    I parse a lot of strings using it.
    No other languages.
    2003-07
    561
    Default Re: ASCII
    There was some posts about changing language pack inside Autocad, would the assci then work but as a different character ? I dont really want to change my language to test.
    Other way may be to make your own character ids a=1 b=2 A=27 and check removing if match occurs.
    2006-04
    466
    Default Re: ASCII
    I thought of using a LIST of characters, and test using MEMBER
    2006-04
    466
    Default Re: ASCII
    I have discovered extended ascii codes.
    does anyone have a good table reference?
    Hopefully I can include characters from other languages.
    Certifiable AUGI Addict
    2001-03
    Tallahassee, FL USA
    3,667
    Default Re: ASCII
    Alt+ https://www.alt-codes.net/
    AutoCAD Text Symbols and Special Characters Reference https://knowledge.autodesk.com/suppo...CDBE1-htm.html
    An engineer friend installed Chinese to produce something but had to uninstall it to get back to working. It wasn't an easy switch.
    2003-07
    561
    Default Re: ASCII
    A simpler way is to explore TTF. Try using word "symbol" in search for true type fonts.
    Dont think of TTF as just a-z they can be anything press "a" and a house appears. We had hundreds of traffic signs.
    2006-04
    466
    Default Re: ASCII
    here's an example table, the numbers don't line up with autocad ASCII extended command codes
    https://theasciicode.com.ar/ascii-pr...i-code-65.html
    ASCII does spit out a code though
    2003-07
    561
    Default Re: ASCII
    The extended characters are not the same in every font what your link shows is for more normal fonts.
    Go C:\windows\fonts pick a font then "Find a character" it will show all the characters. Win10
    2006-04
    466
    Default Re: ASCII
    do you think if i went through the extended ascii set character by character with the ASCII command i could create my own table of numbers that will work as well as the original ascii set does?
    2006-04
    466
    Default Re: ASCII
    Ok I wrote a autolisp program to step through each of the extended ascii characters spread sheet and give me the character code.
    Attached is the result.
  1. 2014: Import ASCII (.ASC) file
    By tim_newsome in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2014-02-25, 01:13 PM
  2. ASCII results
    By dratsiox in forum Robot Structural Analysis
    Last Post: 2011-04-11, 02:32 PM
  3. ASCII Reports
    By civil3d.wishlist1941 in forum Civil 3D Wish List
    Last Post: 2008-11-14, 06:01 PM
  4. ASCII Formating
    By tommy.huckabee in forum AutoCAD Wish List
    Last Post: 2005-04-05, 12:29 PM
  5. ASCII Keyboard Macro??
    By jeanchile78742 in forum AutoCAD Customization
    Last Post: 2005-02-18, 10:16 PM
