Randomly seem to lose library association or some thing and end up with Handle = d2adf error iv tried using NETLOAD to put relink the file but it dose not seem to work. Has any one found a fix for this error?
Error description: Can be modeling pipe in a drawing for a week or more and suddenly every time i go to add a pipe via the grips or aecbpipeadd command I get a pop up window and an error msg "The part specified in the routing preference cannot be used in the layout due to size or angle limitations. Please select a different part to substitute in the layout and click OK. Click cancel to revert to the original part." and then it makes me pick the type of pipe about 6 times (seemingly once for each direction i MIGHT go and then i have to pick what kind of part i want again if i do any thing other then go straight (elbows ect.) ALSO offten the pipe type im using (say butt weld) isnt in the options to pick till the third or fourth selection.
