Thread: LISP Routine - what do I need to do to have a command finish before lisp routine goes on?
    2017-11
    10
    Default LISP Routine - what do I need to do to have a command finish before lisp routine goes on?
    Using autocad 2018
    the revcloud command does not finish, & the lisp routine continues on. Which makes it not work correctly. What do I need to add to make routine wait till revcloud command is done before continuing on with rest of lisp routine?
    Here is what I have:
    (defun C:jt2 ()
      (setq m:sc (getvar "dimscale"))
      (setq m:REVNUM (getstring "\nEnter the revision set: "))
      (command "-layer" "m" (strcat "REVISION_CLOUDS_" m:revnum) "")
      (initcommandversion -1)
      (command "_revcloud" "s" "c" "p" "a" (* 0.5 m:sc) "")
      (setq m:TAGLAY (strcat "REVTAG-" m:REVNUM))
      (setq m:PLACETAG (getpoint "\nPlace the cloud's tag: "))
      (command "-layer" "m" m:TAGLAY "")
      (command "._insert" "cloudtag" m:PLACETAG (getvar "DIMSCALE") "" "0" m:revnum )
      (princ "\nNow place the leader using a 3-point arc. ")
      (command "._arc")
    I appreciate anyone's help
    2009-11
    5,732
    Default Re: LISP Routine - what do I need to do to have a command finish before lisp routine goes on?
    Welcome to AUGI.
    Try adding this WHILE loop:
    ;; <snip>
      (while (= 1 (getvar 'cmdactive))
        (command pause)
    ;; <snip>
    Cheers
    Computer Specs:
    2017-11
    10
    Thanks that worked.
    Have a great day!!!
    2009-11
    5,732
    Quote Originally Posted by jhein759286 View Post
    Thanks that worked.
    Have a great day!!!
    Happy Friday.
    Computer Specs:
  1. LISP Routine that works with AREA command
    By Paul.C.Rasmussen in forum AutoLISP
    Last Post: 2016-01-03, 07:52 PM
  2. Use Saveas Command from a Lisp Routine
    By CADdancer in forum AutoLISP
    Last Post: 2011-06-23, 03:01 PM
  3. LISP routine for Area Command
    By Mac Demer in forum AutoCAD General
    Last Post: 2010-07-14, 06:24 PM
  4. Replies: 14
    Last Post: 2007-09-03, 08:01 PM
  5. BURST command in Lisp Routine
    By mhollar in forum AutoLISP
    Last Post: 2005-12-19, 11:08 PM
