Thread: Text rotating to match ucs
    2009-06
    Toowoomba, QLD, Aus
    74
    Default Text rotating to match ucs
    i am having this issue with text in the editor rotating to match WCS all the time
    this occurs with text, MText and multileaders
    if i leave the UCS set to world and the text horizontal it is normal, but the moment i rotate the text or change to a user coordinate system the text appears as such when editing , sometimes even when creating new entities.
    if editing MText or multileaders, i can select "always display WYSIWYG" from the editor settings and it appears fine for the remainader of that editing session, but need to toggle again for the next session.
    i have tried all different settings for MTEXTFIXED, currently set at 1.
    I have repaired and reinstalled the installation, am currently running version 2018.1.1 with all known updates although this issue was occurring in 2016 (never tried 2017, too many other issues to use that release)
    refer attached image
    Note, it doesnt do it on all drawings, but once it does it won't stop and i have found no particular trigger to make it start.
    2009-06
    Toowoomba, QLD, Aus
    74
    Default Re: Text rotating to match ucs
    I have isolated the problem to a customised toolbar i created. whenever i include it in the customised workspace i get the problem, if i exclude it there is no problem.
  1. Replies: 3
    Last Post: 2017-08-22, 02:14 PM
  2. Rotating and Scaling Images to Match 3d view
    By trconnet in forum AutoCAD 3D (2007 and above)
    Last Post: 2009-06-17, 01:31 PM
  3. Text rotating in text editor.
    By Beancud in forum AutoCAD General
    Last Post: 2009-05-01, 12:49 AM
  4. Replies: 4
    Last Post: 2007-11-26, 10:22 PM
  5. Rotating Text
    By mccurdyks in forum Revit Architecture - Families
    Last Post: 2007-08-02, 12:56 PM
