Thread: Swap surfaces in volume surfaces
    Wish List Administration
    2011-08
    4,581
    Default Swap surfaces in volume surfaces
    Summary: The ability to swap out surfaces in a volume surface
    Description: Sometimes a surface name might change and if a volume surface has already been labeled with surface band elevations, there is no option to swap out a surface in order to keep the labels. I wish there was a way to swap out the old surface with the new surface and keep all tables and labels intact.
    Product and Feature: AutoCAD Civil 3D - Surface Modeling
    Submitted By: t4duzan on 11/29/2017
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,096
    Default Re: Swap surfaces in volume surfaces
    Another method currently available would be to create two dummy surfaces for the base and comparison surfaces. Within these dummy surfaces, paste the desired surface for each type. Then make your volume surface referencing the two dummy surfaces.
    2016-01
    11
    Yep, that's a good work around until an easier solution is available. Thanks for the idea!
